I so have replaced one of my old board with the mks v1.3 and have been working on setting up marlin 2.x
I got everything to the point that I can print but when printing I noticed that it would break up long linear moves into multiple segments which seems to be intended for use with bi-linear bed leveling. The real problem that I found is that if I don't set
#define classic jerk then at the point between segments I get bumps along the surface where its visibly pausing and oozing.
I tried adjusting
JUNCTION_DEVIATION_MM up from 0.02 to 0.04 to 0.1. This helps with the long linear moves but curve segments still end up with a slight pause and oozing.
You can see the
issue during print in this quick video. I have also attached a close up of the part where you can clearly see the issue.
So I'm just curious as to what I may have missed in getting it to work with the new
JUNCTION_DEVIATION_MM setting rather than
#define classic jerk?
Edited 1 time(s). Last edit at 10/15/2019 11:00AM by hcker2000.
open |
download -
(400.9 KB)
