Hello,
I had to reset my EEPROM with an M502 command through Pronterface then saved with M500. I had to do this to fix a probing issue I was having where the EZABL wasn't probing correctly because the probe offset wasn't saving. That problem is fixed but now I'm getting terrible layer shift. Did I screw something up with the M502 and M500?
I recently upgraded to an SKR e3 mini and had reprogrammed everything and gotten it working perfectly. Now it is not working so well. I have performed mechanical checks, belts are tight and nothing else seems wrong.
It seems like now the print bed is moving too fast, but I am not sure how to get this fixed. Below are all of the settings in the speed setting in Cura 4.1. I printed a perfect print yesterday with the exact same Cura settings. All that has changed is resetting the EEPROM settings.
Are there some settings that I need to change after resetting the EEPROM? I am sorry for sounding ignorant, I am not really sure what the EEPROM really is.
You can see my jerk and acceleration settings in Cura that have been successfully working for me so far. I haven't changed any of those settings. I can provide my configuration.h file if needed.
Images:
imgur.com]
