Hi all,
Sorry if this has been asked. I did do a search and didn't find anything.
OK I have a Ender 3 with the SKR Mini (E3V 1.2) motherboard, and I'm having a couple of issues I am hoping y'all can help me fix.
I'll post a copy of the current firmware and upgrades I have done.
So when I try to print something I have to turn the hot end all the way up. For example: The firmament I am using (Hatchbox PLA) "acts" like it has a clog till I turn it up to too 260. When I first got it the temp would be fine. As I have use it the temp needs to be raised to point where I can only print as 260. No matter the filament.
Here's my nebie thoughts. I need a new hot end??? Or E-Stepper motor?? Or software? ...I know a new printer lol
I have updated the firmware to the one post but I am still having the same issuse.
Hardware or software?
I also ran test today and told it to extrude 100mm after I measured it and it was 104mm. So it's pushing out to much filament.
Any ideas?
Settings:
Cura slicer
Temp: 260
Plate: 60
Speed: 50mm S
Layer: .01
Tip: .4
Feed Rate: 113% (set before new feed rate was discovered)
Retraction: 8
Retraction Speed: 80
Upgrades:
Aluminum Extruder
SRK Mini
Glass Bed
Yellow Springs with Lock Nuts
Bulls eye cooling system
LED light bar.
Winsinn 24v 40mm fans (3)
Printed blue V slot rails
I tried to think of everything you would need to help troubleshot. If you need any more info please ask and I"ll get it posted.
TIA
James
open |
download -
firmware (2).bin
(224.3 KB)
open |
download -
(44.6 KB)
