I'm currently rebuilding my board. I would like to use closed loop motors with the CPR encoders on the back from Stepperonline for my X and Y.
Unfortunately my TMC5160 only offer an encoder interface with ABN.
Now I have found the TMC4361 which offers an interface for the CPR encoder. The data sheet of the TMC4361 shows an example structure which shows that a closed loop can be implemented with the TMC4361 as a motion controller and the TMC5160 behind it as a motor gate driver.
Is there compatibility with the TMC4361 from Marlin? How can you imagine the structure? If the TMC4361 is the motion controller and the TMC5160 is only the gate driver, can I simply set the driver 5160 in Marlin and Marlin then treats the 4361 like a 5160?
Please do not be confused by the picture, the tmc4361 has step and dir input pins which it then passes out from the output pins to the 5160 which I will use.
greetings
Dominik
Edited 4 time(s). Last edit at 08/21/2020 01:59AM by TrashCo92.
