Compilation problem October 12, 2021 01:55AM |
Re: Compilation problem October 12, 2021 02:28AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Compilation problem October 12, 2021 02:29AM |
Re: Compilation problem October 12, 2021 08:24AM |
Re: Compilation problem October 12, 2021 09:48AM |
Re: Compilation problem October 12, 2021 12:46PM |
Re: Compilation problem October 12, 2021 03:35PM |
Re: Compilation problem October 12, 2021 04:04PM |
Re: Compilation problem October 12, 2021 04:50PM |
#if ENABLED(PID_PARAMS_PER_HOTEND) // Specify up to one value per hotend here, according to your setup. // If there are fewer values, the last one applies to the remaining hotends. #define DEFAULT_Kp_LIST { 22.20, 22.20 } #define DEFAULT_Ki_LIST { 1.08, 1.08 } #define DEFAULT_Kd_LIST { 114.00, 114.00 } #else #define DEFAULT_Kp 22.20 #define DEFAULT_Ki 1.08 #define DEFAULT_Kd 114.00 #endif
#if ENABLED(PIDTEMPBED) //#define MIN_BED_POWER 0 //#define PID_BED_DEBUG // Sends debug data to the serial port. // 120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+) // from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10) #define DEFAULT_bedKp 10.00 #define DEFAULT_bedKi .023 #define DEFAULT_bedKd 305.4 // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles. #endif // PIDTEMPBED
