Y homing wrong...
Posted by pmarzin
Y homing wrong...
February 03, 2022 12:10PM
I just updated my firmware on my geeetech i3 pro b. Marlin 2.0.9.3 compiled and uploaded fine. Now, I face 2 problems:
My sd card isn't detected (2004D lcd panel) , no matter the options I define in config and configadv.
Y homing doesnt work: every time I hit Autohome, X and Z home correctly, but Y goes forward by 10 mm, whatever Y current position...
Any clue? Thanks for answering!
VDX
Re: Y homing wrong...
February 03, 2022 02:41PM
... it seems, you changed the pin-definitions, what is done in a "configuration" section -- search a correct setting for your hardware or the information to do this on your own ...
Edited 1 time(s). Last edit at 02/03/2022 02:41PM by VDX.
Viktor
February 03, 2022 07:43PM
Y end stop is showing all the symptoms of always being constantly triggered.
February 03, 2022 08:46PM
I have noted after I have flash the Marlin 2.0.9.3 firmware if you do not initialize EEProm some functions do not work correctly.
Click
Select Configuration Click
Select Advanced Settings Click
Initialize EEProm Click
When I install Marlin 2.0.9.3 on my controller none of the steppers motors worked an various other problems.
After completing above procedure all work as intended.
Edited 1 time(s). Last edit at 02/03/2022 08:47PM by Roberts_Clif.
February 07, 2022 10:42PM
post config.h and config_adv.h
Check M119 report?
