Hello,
I have a Two Trees Sapphire Plus with MKS Robin Nano v1.2 motherboard and 5xTMC2225 stepper drivers.
Because those don't support Linear Advance and since it's cheap I replaced the extruder driver with a TMC2209 to enable Linear Advance.
I changed the driver type in the firmware with the appropriate one. I calibrated the extruder and when asked to extrude 100mm it does so but when I start a print ,it over extrudes a lot. The print gets so squishy that eventually it bumps on hotend and messes everything up.
Also the motor makes loud metal noises when retracting.
If I replace the 2209 with the 2225 and flash the stock firmware, it works fine.Same happens with Linear Advance on or off.
I updated my firmware (I was using Marlin Bugfix 2.0.9 and updated to Bugfix 2.1.2) but no change.
TLDR. Changed extruder stepper from 2225 to 2209, changed the type in the firmware but extruder overextrudes when printing. When manually asking for 100mm it extrudes 100mm.
I use Cura with no changes to profile with either stepper driver.
Is there something else that should be changed in the firmware or the stepper driver?Maybe a jumper or some other setting?
All drivers are on standalone mode.
Thanks
