I try to build Marlin for debugging. Compiling in release (default) configuration works fine. however, if I add "build_type = debug" to the [env] section (as instructed by
this page), I immediately get a ton of problems listed, I don't even need to compile. Basically, every “#if ENABLED...” phrase gives an "function call is not allowed in a constant expression” error. What is going on?
