Problems after Firmware update on duet 0.85 April 27, 2016 03:34AM |
Re: Problems after Firmware update on duet 0.85 April 27, 2016 05:49AM |
Re: Problems after Firmware update on duet 0.85 April 27, 2016 07:39AM |
; Thermistors ;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 T100000 B3974 R1000 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
Re: Problems after Firmware update on duet 0.85 April 27, 2016 09:23AM |
Re: Problems after Firmware update on duet 0.85 April 27, 2016 10:24AM |
Re: Problems after Firmware update on duet 0.85 April 27, 2016 11:56AM |
Re: Problems after Firmware update on duet 0.85 April 29, 2016 02:43AM |
Re: Problems after Firmware update on duet 0.85 April 29, 2016 09:01AM |
