Cannot Connect Duet May 19, 2016 01:43PM |
Re: Cannot Connect Duet May 19, 2016 01:57PM |
Re: Cannot Connect Duet May 23, 2016 09:45AM |
Re: Cannot Connect Duet May 23, 2016 11:10AM |
Re: Cannot Connect Duet May 25, 2016 08:13AM |
Re: Cannot Connect Duet May 26, 2016 08:29AM |
mg0353
Thanks, I updated the drivers and that let me connect. That problem solved I've now moved on to another..
I had the printer up and running - everything working correctly until I tried auto-bed levelling. The Board is wired as shown in the pictures attached to my first post.
First time I tried it, the printer cut out as it was moving to the third test point. Printer stopped moving, duet lost connection and a high pitched whining came from the board. I switched it off at the mains. Restarted and tried again... Second time the same thing happened (movement stopped, connection lost) but no high pitched whining. I've since been unable to connect via USB or via ethernet. The duet now comes up as an unknown device on the computer even though the drivers were installed previously. When pinging the board via command prompt the response is 'destination host unreachable'
Any ideas as to what might have happened and what might've caused this?
Thanks in advance
