What is the easiest way to add an E-stop to the Duet? July 15, 2016 06:41AM |
Re: What is the easiest way to add an E-stop to the Duet? July 15, 2016 06:50AM |
Re: What is the easiest way to add an E-stop to the Duet? July 15, 2016 08:33AM |
Re: What is the easiest way to add an E-stop to the Duet? July 15, 2016 12:28PM |
Theolodian
OK, thanks. In the future it would be nice if the endstops were interrupts and any endstop (including E0/E1) could be used as an emergency stop (print stop) without resetting the board.
Just constructive feedback, I appreciate that I'm not paying you for this so don't stress about it. Thanks again!
Re: What is the easiest way to add an E-stop to the Duet? July 15, 2016 12:56PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: What is the easiest way to add an E-stop to the Duet? July 15, 2016 03:41PM |
No hardware e stop button I've ever used "restarts when released again" for a good reason, safety. Without exception they require positive intervention to reset the switch physically and require you to acknowledge in the control that you are recovering from an e-stop condition. Sometimes going as far as requiring a reset of the control. The last thing I would ever want is for a machine to begin running again once I took my hand off the e stop switch.Quote
VDX
... there are several "stop"-options with software and hardware:
- software - "Normal" Stop in software with Resume possibility - the G-codes in the buffer/queue will be executed before stopping
- software - "Normal" Stop in software without Resume possibility - the G-codes in the buffer/queue will be executed before stopping
- software - "Emergency Stop" per G-code "M112" - all motors and heaters will be shut down instantly ... restart with "M999"
- hardware - "Emergency Stop" - external emergency button, which shuts down the power ... restart when released again ...
Re: What is the easiest way to add an E-stop to the Duet? July 16, 2016 09:31AM |
