Teilchen
Gentlemen,
I have tried to use a search function with no success, perhaps used the wrong search criteria...
I would like to know the maximum Hotend heater power that the Duet can handle... I am running at 24V, so how much current can I draw off from E0 and E1 terminals?
Thanks!
I don't believe it's been defined, however the limiting components will be the E0 and E1 heater terminal blocks, which I believe are rated at 5A.
If you are using 24V power, then you need 24V heater cartridges in your hot ends.
Edited 1 time(s). Last edit at 08/21/2016 11:33AM by dc42.
