There appears to be a mismatch between DWC 1.12 and Firmware 1.15e/1.16 on git hub.
Basically, DWC is expecting to see in the firmware a cputemp and cputemp cur property but the firmware only sends these two properties for mcutemp and not cputemp. A quick fix for anyone who wants to restore the CPU temperature is to change /www/js/comm.js on their SD card to look at the mcutemp property. At line 315 update the code to look like this.
if (status.hasOwnProperty("mcutemp") && status.mcutemp.hasOwnProperty("cur")) {
$(".cpu-temp").removeClass("hidden");
$("#td_cputemp").html(T("{0} °C", status.mcutemp.cur.toFixed(1)));
@dc42 Would you be able to add the cur property to the cputemp in your firmware in a future release? This should then just work without needing any modifications to DWC.
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
