Duet 0.6 Burnt EO Heater Ground Now No Web Control Access May 04, 2017 12:23PM |
Re: Duet 0.6 Burnt EO Heater Ground Now No Web Control Access May 04, 2017 07:21PM |
Re: Duet 0.6 Burnt EO Heater Ground Now No Web Control Access May 05, 2017 02:17PM |
dc42
There is no E0 heater ground terminal and no connection between the E0 heater terminals and the Ethernet system.
If one of the E0 terminals is discoloured, this probably means that the screw in the terminal worked loose.
The Ethernet issue may be different. On older Duets the soldered connections between the Ethernet PHY chip and the PCB were sometimes less than perfect and could be intermittent. I have repaired several boards by re-soldering or replacing the chip. Later Duet 0.8.5 boards used a different PCB pattern to eliminate the problem.
Re: Duet 0.6 Burnt EO Heater Ground Now No Web Control Access May 05, 2017 02:23PM |
Re: Duet 0.6 Burnt EO Heater Ground Now No Web Control Access May 05, 2017 11:47PM |
dc42
It's not the Ethernet connector that sometimes causes problems, it's the square chip that connects the processor to the Ethernet connector. If that's the problem, it needs hot air soldering equipment and sometimes a new chip to fix it.
You don't need to use M586 to use HTTP protocol, you only need it if you want to use FTP or Telnet.
