Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 06, 2017 11:34AM |
Re: Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 06, 2017 02:06PM |
Re: Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 06, 2017 10:16PM |
dc42
Which fan output do you have the hot end fan connected to, and how have you configured it in config.g? Are you sure that the cabling is sound?
Re: Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 07, 2017 01:50AM |
Re: Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 07, 2017 05:47AM |
o_lampe
The fans are connected to EO and E1 on the Duet Ethernet board.
I don't have my DuetWifi at hand, so I can't check....but it sounds like you powered the fans through the Extruder ports? Or are there fan ports called E0, E1?
Forgive me if I'm wrong, just shooting from the hip.
Re: Duet Ethernet Hotend Fan Turns Off and On during print and clogs nozzle July 07, 2017 11:36AM |
dc42
o_lampe
I agree, that's what it sounds like. The hot end fan should be connected either to one of the always on fan connectors, or to the Fan1 connector and Fan1 left in thermostatic mode - or you could connect it to the Fan 2 output if you are using Fan 1 for something else and configure Fan 2 in thermostatic mode.
