Duet Wifi SSR wiring for 'soft on' button. March 11, 2018 08:55AM |
Re: Duet Wifi SSR wiring for 'soft on' button. March 11, 2018 07:58PM |
Re: Duet Wifi SSR wiring for 'soft on' button. March 12, 2018 09:43AM |
dc42
1. Connect the negative SSR control terminal to PS_ON, and the positive control terminal to either +5V or +3.3V from the expansion connector.
2. I've never heard of an SSR leaking enough to start the sorts of power supplies used to power 3D printers. If it did, then the symptom would be that the power supply runs in very short bursts at regular intervals. A remedy would be to put a light resistive load in parallel with the mains input terminals of the PSU. Something like a 120K 0.5W resistor with an appropriate voltage rating.
Re: Duet Wifi SSR wiring for 'soft on' button. December 07, 2018 02:12PM |
Re: Duet Wifi SSR wiring for 'soft on' button. December 07, 2018 03:53PM |
Re: Duet Wifi SSR wiring for 'soft on' button. April 11, 2019 11:02PM |
Re: Duet Wifi SSR wiring for 'soft on' button. April 12, 2019 02:45AM |
Re: Duet Wifi SSR wiring for 'soft on' button. April 14, 2019 07:39PM |
Re: Duet Wifi SSR wiring for 'soft on' button. April 14, 2019 07:48PM |
