I suspect I'm doing something wrong, but this is now driving me nuts.
I made sure the jumper was set to 3.3v and connected the PanelDue to a 7" screen and plugged it into my USB port only. The screen came on but showed funny lines as I expected so thought all I needed to do was load the right firmware.
I pressed and held erase for a couple of seconds and then pressed reset. I now have a black 7" screen with the backlight on.
The issue is the PanelDue just will not get recognised by either Windows 7 or 10 (different laptops) (no USB connection sound or unknown/odd devices in device manager) and also under Linux when connecting no ports are detected when checking dmesg.
I've also tried to connect it without the display attached but that too has the same issue. I also tried two different cables, one that came with the Duet 0.6 which I previously used to flash firmware and one other I had. Same results.
I have also tried holding erase and reset for longer in case the instructions had changed for this 1.1 version but no joy.
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
