X/Y movements reversed. Kind of...
Posted by Mr Spangles
August 12, 2016 08:31PM
Hello chaps,
So I've got to the commissioning/calibration phase of my D-Bot coreXY build using a Duet 0.8.5 and everything seems OK, except for the X move commands resulting in front/back motion, and Y moves resulting in left/right (via the web server).
I've tried swapping the X/Y connectors on the board, but that makes no difference.
They're wired correctly according to all the diagrams, so I'm a bit baffled here.
I'm running DC42's RRF 1.14 along with the CoreXY sys config.
Cheers for any advice, and let me know if you need more info.
Re: X/Y movements reversed. Kind of...
August 12, 2016 09:39PM
You might have to tell one of your motors, either X or Y to run reverse to get the motion correct. On both my CoreXY Duet printers it looks like the following:
M569 P0 S0;							; (X axis) Drive 0 goes reverse
M569 P1 S1;							; (Y axis) Drive 1 goes forwards
This makes the X move from left (0) to right (300) and Y moves from front (0) to back (300).
August 12, 2016 09:53PM
Thank you very much. That sorted it out smiling smiley
Well, the other way round in my case.
M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it)
M569 P1 S0 ; Drive 1 goes forwards
ED:
Actually, they should be the same as your settings, but I forgot that I hadn't switched the plugs back to normal yawning smiley
Edited 1 time(s). Last edit at 08/12/2016 11:33PM by Mr Spangles.
