Mapping hot-end heater to Bed heater terminals October 13, 2016 07:11AM |
; Prologue and comms section M111 S0 ; Debug off M550 P3dprint ; Machine name (can be anything you like) M551 P******** ; Machine password ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P192.168.1.240 ; IP address (0 = use DHCP) M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin M575 P1 B57600 S1 ; Comms parameters for PanelDue ; Movement section M569 P0 S1 ; Drive 0 goes forwards (change to S0 to reverse it) M569 P1 S1 ; Drive 1 goes forwards M569 P2 S0 ; Drive Z goes backwards M569 P3 S0 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M574 X2 Y1 Z0 S2 M574 E S1 ; set endstop configuration (X and Y endstops only, at low end, active high) M906 X700 Y900 Z1000 E1200 I50 ; Set motor currents (mA) M201 X130 Y130 Z15 E1000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z200 E2000 ; Maximum speeds (mm/min) M566 X1000 Y1000 Z30 E90 ; Minimum speeds mm/minute M208 X340 Y340 Z340 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed) M92 X80 Y80 Z1600 ; Set axis steps/mm M92 E146:146 ; Set extruder steps per mm G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Z probe section M558 P4 X0 Y0 Z1 H2 F100 T5000 ; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min G31 X16.0 Y-35 Z1.675 P500 ; Set the probe height and threshold (put your own values here) ; Heater and thermistor section ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands M143 S300 M570 S120 M140 H1 M305 P0 R4700 T100000 B4388 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R4700 T92000 B4388 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M307 H1 A464.1 C1545.8 D65 S0.6 B0 M307 H0 A1499.9 C209 D5 S0.4 B0 ;M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0 ;M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1 ; Increase to allow extra heating time if needed ; Tool definition section M563 P0 D0 H0 ; Define tool 0 to use extruder drive 0 and heater 1 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;*** If you have a dual-nozzle build, un-comment the following 2 lines ;M563 P1 D1 H2 ; Define tool 1 ;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ; Epilogue ;*** If you are using axis compensation, put the figures in the following command M106 P0 F30 M106 P1 S100 F30 T50 H0 M572 D0 S0.08 M556 S78 X0 Y0 Z0 ; Axis compensation here T0 ; select first hot end
Re: Mapping hot-end heater to Bed heater terminals October 21, 2016 04:36AM |
Re: Mapping hot-end heater to Bed heater terminals October 21, 2016 09:38AM |
Re: Mapping hot-end heater to Bed heater terminals October 21, 2016 10:37AM |
Re: Mapping hot-end heater to Bed heater terminals October 21, 2016 11:37AM |
Re: Mapping hot-end heater to Bed heater terminals October 21, 2016 12:56PM |
