Tool Change code February 28, 2017 03:34PM |
Re: Tool Change code February 28, 2017 05:22PM |
Re: Tool Change code February 28, 2017 06:55PM |
Re: Tool Change code March 01, 2017 03:04AM |
Re: Tool Change code March 01, 2017 03:31AM |
Re: Tool Change code March 01, 2017 06:54AM |
Re: Tool Change code March 02, 2017 11:12AM |
Re: Tool Change code March 07, 2017 04:38PM |
Re: Tool Change code March 08, 2017 07:46AM |
joestefano
David, "The tfree1.g, tpre1.g and tpost1.g files would be similar, except that tpre1.g would use command M116 P1." is this statement correct in regards to the tpre1 including M116 P1? I thought that M116 P# belongs in the tpost1 file
Re: Tool Change code March 08, 2017 08:18PM |
Re: Tool Change code March 09, 2017 02:40AM |
Re: Tool Change code March 09, 2017 05:28AM |
Re: Tool Change code March 09, 2017 02:27PM |
Re: Tool Change code March 09, 2017 04:43PM |
Re: Tool Change code March 10, 2017 01:50AM |
Re: Tool Change code March 11, 2017 11:28AM |
Re: Tool Change code March 11, 2017 01:37PM |
IMBoring25
Speaking of G10, is there a reason it waits until the specified tool is activated to implement active and standby temperature changes since I upgraded to the 1.17 branch?
Re: Tool Change code March 13, 2017 08:22PM |
dc42
I suggest something like this in your start gcode:
G10 P0 S[first_layer_temperature] R150
Repeat the G10 command for each tool you are using, and replace the R parameter by whatever standby temperature you want. I think most slicers recognise the first_layer_temperature parameter.
Re: Tool Change code October 14, 2017 01:44PM |
