PID Bed Tuning Over-power Warning
Posted by jbolt
December 03, 2017 06:55PM
What is the relevance of the over-power warning during PID tuning?
I have a 400mm x 400mm x 6.35mm MIC-6 aluminum plate heat bed with a 110vac 1200w Keenovo heating pad. The purpose being for quick heat up.
At 100% PWM the heat time is 2-1/2 minutes to 80c from ambient (20c) but I get an over-power warning. On the PID tuning I decreased the PWM percentage by 0.2 increments until I no longer got the warning at PWM of 20% but at the cost of a 16 minute heat time.
If I use the PID values at the level that did not trigger an over power warning do I need to use the lower PWM value in the M307 or can I run a higher PWM value with those PID settings?
Or do I run at the PID values of a higher PWM % that give a reasonable heat time and rely on a thermal cut-off fuse for protection?
Not sure how to interpret all this???
Re: PID Bed Tuning Over-power Warning
December 03, 2017 07:13PM
Basically it's telling you what temperature the bed might reach if there is a fault that causes the bed to run at full power. You have to assume that under fault conditions there could be 100% PWM. So when using fast bed heaters like yours, it's wise to mount an over-temperature cutout on the bed and connect it in series with the bed heater.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
December 03, 2017 07:21PM
Is it correct to say that if the PID tuning (at whatever PWM% I chose) is stable, I use those PID values and rely on the thermal protection I am comfortable with in case of a fault, regardless of the warning?
December 04, 2017 03:10AM
Whether you add a thermal cutout is up to you; but if the predicted temperature at full power is significantly higher than the temperature limit of the heater, then I recommend it strongly. Thermal cutouts are commonly used in domestic appliances for similar reasons.
December 04, 2017 05:42PM
Can you recommend a thermal cutout for us plz smiling smiley
December 04, 2017 06:50PM
Yes I am running a thermal fuse.
December 05, 2017 06:00PM
something like this:
[www.aliexpress.com]
just held onto the bottom of the hot bed and wired in series I take it?
December 05, 2017 06:08PM
JustSumGuy
Yes, but pick a lower temperature one because 260C is too hot for a silicone heater.
December 06, 2017 01:17AM
dc42
JustSumGuy
I read 200c in that link...
I have a 24v MK3
December 06, 2017 08:17PM
I'm using a NTE8182 thermal fuse with a 192c cutoff. It was recommended by others to stay away from the no-name imports from China due to inconsistencies.
December 07, 2017 01:11AM
jbolt
I am sure its made in china regardless, I dont buy into that hype and after spending thousands on aliexpress over the last decade I haven't experienced it either.
That said, how did you mount it? just put it under the heat bed?
December 07, 2017 01:26AM
My bed is 1/4 aluminum so it is clamped to the back edge similar to the example in this thread, fourth post down. [forums.reprap.org]
December 07, 2017 11:41AM
jbolt
tqvm
