CNC vs 3D Print February 16, 2023 08:06PM |
Re: CNC vs 3D Print February 16, 2023 08:15PM |
Admin Registered: 16 years ago Posts: 13,898 |
Re: CNC vs 3D Print February 16, 2023 08:22PM |
VDX
... want you compare 3D-printing vs. lost cast molding from 3D-printed wax parts?
Made something for one of my sisters this way - the "master" was resin-printed, then copied into wax, then LC-molded ... was around 3-5 Euros per part for 100 pieces:
[attachment 120152 101Freyas.jpg]
Re: CNC vs 3D Print February 17, 2023 02:29AM |
Re: CNC vs 3D Print February 17, 2023 07:12AM |
Re: CNC vs 3D Print February 17, 2023 09:54PM |
Re: CNC vs 3D Print February 18, 2023 04:53PM |
dekutree64
I see no reason to use metal at all anymore. Tom Brazier's style of carrier with integrated hollow posts is a thing of beauty. With a bit of trial and error you can get it to print out ready to use, no cleanup needed (attachment Carrier.jpg). With a belt printer you could just put a bucket at the end and print more than you could ever sell
So the only difficult production steps are drilling the motor shaft and grinding the cutter bearing flange. I bought a NEMA11 but haven't made a drilling jig for it yet. Hopefully it will go easily this time by drilling it from both ends.
Re: CNC vs 3D Print February 18, 2023 08:19PM |
Re: CNC vs 3D Print February 18, 2023 08:58PM |
yet-another-average-joe
An idea about drilling the shaft...
With a drill press (fixed part, spinning drill bit), the drill tends to deviate. Moreover, drill press chucks usually have a huge runout. With a lathe it's the opposite : the drill tends to auto center, even without center drilling, or with a poorly aligned tailstock. It's a fact, experienced it many times, never understood why... Recently confirmed, one more time, by an old retired machinist.
What about spinning the motor while keeping the drill bit fixed ?
1000-2000 RPM is on the low side for a 2mm drill bit, but could do it.
Could even spin the drill press and run the motor in the opposite direction, adding RPMs...
[EDIT] I use split point drills only, and always with collets. My feelings could be biased
Re: CNC vs 3D Print February 18, 2023 11:49PM |
Yeah, regular PLA will certainly work. It just might need replaced periodically, whereas PLA+ with coarse threads will probably be trouble-free for many years.Quote
rq3
I probably printed 100 prototypes in PLA, and they worked fine as long as the motor didn't get too warm.
I shall add that to my list of desired tools!Quote
rq3
135 degree, split point, 2mm diameter high speed steel bit
Re: CNC vs 3D Print February 20, 2023 02:48PM |
Re: CNC vs 3D Print February 26, 2023 02:49AM |
Re: CNC vs 3D Print February 26, 2023 08:25PM |
Re: CNC vs 3D Print February 27, 2023 12:43PM |
dekutree64
Initial printing tests are not looking good. Lots of underextrusion, especially at the start of each line. Retract moves were failing entirely (vibrating in place) until I lowered the max velocity to 3mm/s, and still sometimes failed to de-retract. 2mm/s doesn't visibly skip, but apparently is still missing some steps.
It's also back to not following the helix after retracting, probably due to the decreased blade penetration.
The 300mA current rating seems to be quite conservative actually. I went up to 450 and the motor was still not too hot to keep my hand in contact with it. I didn't push it to 500, but that would probably be comparable to the level of heating you get with the rated current of NEMA17 steppers.
Maybe my imperfect shaft hole is giving it some resistance. I could drill it out to 2.5mm like I did on the NEMA14 before.
Re: CNC vs 3D Print February 27, 2023 08:34PM |
leadinglights
A medium-scale way of doing the bearing carrier is to make up a jig that could be fitted in a lathe chuck so that each of the bearing mounting surfaces and internal threads could be cut before turning the block 120º to turn the next position. Old-fashioned (pre-CNC) machinists would make 100 of these before breakfast.
Nice to see that your project is ongoing.
Mike
