Errore Slicing con CURA January 28, 2014 06:02AM |
;Generated with Cura_SteamEngine 13.12 M140 S70.000000 M109 T0 S240.000000 T0 M190 S70.000000 ;Print time: #P_TIME# G21 ;metric values G90 ;absolute positioning G28 X0 Y0 ;move X/Y to min endstops G28 Z0 ;move Z to min endstops G1 Z15.0 F9000 ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F9000 ;Put printing message on LCD screen M117 Printing... ;Layer count: 100 ;LAYER:0 M107 G0 F3600 X85.25 Y78.75 Z0.30 ;TYPEKIRT G1 F2400 E0.00000 G1 F1200 X112.75 Y78.75 E0.64657 G1 X112.75 Y106.25 E1.29313 G1 X85.25 Y106.25 E1.93970 G1 X85.25 Y78.75 E2.58629 G0 F3600 X85.75 Y79.25 G1 F1200 X112.25 Y79.25 E3.20934 G1 X112.25 Y105.75 E3.83239 G1 X85.75 Y105.75 E4.45544
; generated by Slic3r 1.0.0RC2 on 2014-01-28 at 10:00:38 ; layer_height = 0.2 ; perimeters = 3 ; top_solid_layers = 3 ; bottom_solid_layers = 3 ; fill_density = 0.2 ; perimeter_speed = 20 ; infill_speed = 20 ; travel_speed = 60 ; nozzle_diameter = 0.5 ; filament_diameter = 3 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.50mm ; infill extrusion width = 1.02mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.85mm ; first layer extrusion width = 0.40mm G21 ; set units to millimeters M190 S80 ; wait for bed temperature to be reached M104 S230 ; set temperature M106 S255 ; Start the extruder fan! G92 E0 G1 E2 ; prime the extruder G92 E0 M109 S230 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 G1 Z0.200 F3600.000 G1 X85.160 Y85.160 F3600.000 G1 E1.00000 F1800.000 G1 X86.200 Y84.310 E1.01602 F1800 G1 X87.380 Y83.680 E1.03197 G1 X88.670 Y83.290 E1.04804 G1 X90.000 Y83.160 E1.06397 G1 X109.990 Y83.160 E1.30235
Re: Errore Slicing con CURA January 28, 2014 06:54AM |
Re: Errore Slicing con CURA January 28, 2014 07:35AM |
Re: Errore Slicing con CURA January 28, 2014 07:45AM |
Error: No Line Number with checksum, Last Line:25 Serial Error: Line Number is not Last Line Number+1, Last Line:26 Serial Error: Line Number is not Last Line Number+1, Last Line:26 Error: checksum mismatch, Last Line:32 Serial Error: Line Number is not Last Line Number+1, Last Line:32 Error: checksum mismatch, Last Line:42 Error: checksum mismatch, Last Line:50 Error: checksum mismatch, Last Line:56 Error: checksum mismatch, Last Line:64 Error: checksum mismatch, Last Line:74 Error: checksum mismatch, Last Line:86
Re: Errore Slicing con CURA January 28, 2014 08:35AM |
Re: Errore Slicing con CURA January 28, 2014 12:40PM |
