UK supply for insulated nichrome wire?
Posted by AgeingHippy
August 11, 2010 08:18AM
Hello All
Does anyone have a UK source for insulated nichrome wire?
Cheers
I have been searching for this as well but not come up with anything yet.
Have found this [wires.co.uk] which is bare nichrome which I plan on using to build a HBP for my Mendel project...
If I find anything I will post it up otherwise I think I'll be sourcing some from mendel-parts.com.
If you could ping anything you find up that would be great as well!
Cheers,
Iain
Re: UK supply for insulated nichrome wire?
September 24, 2010 07:24AM
Hi Ian
Thanks for the feedback.
On recommendation by AKA47 I have decided to follow the heater block rout pioneered by nophead. Adrian has posted an updated hot end design on the wiki here which has links to suppliers for the resistors...
I have asked Leeds metal Supermarket for a quote on aluminium and brass rod to make the block from. Once I get feedback from them I will post info here.
All in all I think the heater block is more elegant and tidier than nichrome so no longer looking for nichrome.
Having said that, I may consider it when I get to build my heated bed... that is still months away.
Cheers
