Проблема при настройке отступов (M206, G10) May 26, 2014 08:29AM |
»>M206 X-57 Y-3 SENDING:M206 X-57 Y-3 »>G10 X-57 Y-3 SENDING:G10 X-57 Y-3
SENDING:M503 echo: Steps per unit: echo: M92 X87.49 Y87.49 Z4000.00 E660.00 echo: Maximum feedrates (mm/s): echo: M203 X300.00 Y300.00 Z3.00 E45.00 echo: Maximum Acceleration (mm/s2): echo: M201 X800 Y800 Z30 E250 echo: Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X-57.00 Y-3.00 Z0.00 echo: PID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 Slave not working! Default values are: M301 H2 P12.00 I2.20 D80.00 W125.00 Slave not working! Default values are: M301 H3 P12.00 I2.20 D80.00 W125.00 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01 Bed/extruder 1 beta: 4138.00 resistor: 4700.00 thermistor: 99999.91 inf: 0.09 Bed/extruder 2 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00 Bed/extruder 3 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00 Extruder: 1 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00 Extruder: 2 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
