Yes I use a polypropylene chopping board which seems to come 10mm thick. I think that that is because PP is quite flexible. I also tried HDPE chopping board which is only 5mm thick and much more rigid. The PP worked best because the HDPE board tended to warp due to the localised heat from the object. Maybe it could be glued down but PP doesn't seem to suffer in the same way.
Yes the board is reusable over and over again if you get the temperature of the first layer and the z offset right. Mine has damage due to my extruder spitting out its nozzle but I haven't bothered replacing, or even turning it over, yet.
PCL (CAPA) doesn't seem to stick to it, possibly because the temperature is too low, so I may switch to MDF for that.
www.hydraraptor.blogspot.com]
