DMLS -Direct Metal Laser Sintering- The datum point
Posted by Sofienne
I'm a French student studying the DMLS process and I'm very interesting in what are you saying, but I need some help.
I know that DMLS machines tend to be hard to set and position work accuratly. There are two main issues associated with accurate work location on DMLS machines:
* The build platforms upon which the metal is sintered do not have any form of positional location to the main build chamber within the sintering machine.
*The datum point for the laser in not known. The laser has a home position that is based on the positioning of the mirrors that reflect the laser beam into the build chamber.
So I'm looking for a procedure to allow the datum position of the laser to be measured and thereby related to the position of the fixture.
Thank you
Re: DMLS -Direct Metal Laser Sintering- The datum point
November 14, 2009 12:17PM
Try the rpml mailing list. They can help you.
[rapid.lpt.fi]
DMLS sounds cool. Let us know if you want try to build it into a post-Mendel RepRap. smiling smiley
There's a fair number of francophone and France based reprap builders if you poke around in the forums and on the map, by the way.
This link I made for you so you can learn all about the processes.
http://directmetallasersintering.blogspot.com/
Sofienne,
Not certain if you have heard of a company called Concept Laser or a technology called LaserCusing, but they offer a system with a built in reference system from Erowa or System 3R. It is a German company and Concept Laser use premachined parts and offline presetting to accurately locate and transfer position data to the Concept Laser machine.
LaserCusing is a brand name from Concept Laser and is a combining of the word fusing with Concept, and is a powderbed layer by layer fully melting process, just google LaserCusing and you will find out more details.
I hope this helps
CC
You can check out GPI Prototype website
http://gpiprototype.com
or visit this blog to get info on how much the parts cost
http://directmetallasersintering.blogspot.com/2010/01/dmls-direct-metal-laser-sintering-costs.html
Tim
