Pressure Block for Wade's Extruder December 06, 2010 08:43AM |
Re: Pressure Block for Wade's Extruder December 06, 2010 09:35AM |
... for the idler * 1 X 608 bearing (Skateboard bearing); * 1 X M8X20 piece of smooth bar, threaded bar or a bolt; * 4 X M4X45 bolts; - hex head will work best (they won't turn), and longer than 45 mm will be easier to assemble if you can find them. * 4 X M4 nuts; * 4 X M4 washers; * 4 X Springs - 1 mm diameter wire, wound to an OD of 10 mm, with 4 active coils. For a given filament drive force, you'll need about twice the spring force - ie, if you want 100 N of filament drive, your springs need to push with about 50 N each. NOTE: some users have theirs extruders working without this springs, but springs are recommended. * 16 M4 washers; - optional; 4 washers on each M4X45 idler bolt between the main block and the idler block will limit the idler travel and make reloading filament easier.
Re: Pressure Block for Wade's Extruder December 09, 2010 11:02AM |
Re: Pressure Block for Wade's Extruder December 09, 2010 11:36AM |
MichaelT
We printed all parts but found that we needed something to pressure the filament into the hobbed bolt. As far as I remember it didn't say how to do this, so we decided to make our own pressure block.
Re: Pressure Block for Wade's Extruder December 13, 2010 06:31AM |
Re: Pressure Block for Wade's Extruder December 15, 2010 01:46PM |
Re: Pressure Block for Wade's Extruder December 15, 2010 03:29PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Pressure Block for Wade's Extruder December 19, 2010 03:24PM |
