Anyone used a ring heater?
March 14, 2011 11:51AM
has anyone tried a ring heater to heat up the extruder?
Re: Anyone used a ring heater?
March 14, 2011 12:05PM
I haven't seen one small enough.
March 14, 2011 12:43PM
smallest one that I can afford is 1". At $47 from macmaster carr, it's a reliable clamp on solution. That does mean that I have to use a 1" tube. These goes up to 1500'f, an aluminum tube should be ok right? If not then I can make an aluminum sleeve over my existing 1/2' tube.
March 17, 2011 02:53PM
I've seen quite a few band heaters on Ebay - here's a very inexpensive little 3/4" unit: [cgi.ebay.com]
[haveblue.org]
March 18, 2011 04:16PM
Problem is all the band heaters out there are for 120V+
I'm looking into getting a run of 12V ones made. All the current heater solutions are pretty bad so something like this has to happen eventually.
March 18, 2011 10:21PM
I don't see any issues with the resistor-block heaters. They are very cheap too. Even nichrome is fine if done similar to how the makergear hot ends are.
However, a simple clamp-on heater like Have Blue linked to would be nice.
March 19, 2011 04:55AM
The problem is that they are 1" long. That would give a long melt zone compared to the resistor heater block, which can be only 8mm thick.
