Anonymous User
How is it made?
January 14, 2008 02:04PM
Zach,
How do you make the plastic part of the barrel that the metal tip screws into? Do you mold it, or do you mill it? What type of material is it? Please let me know.
Thanks
Edited 1 time(s). Last edit at 01/14/2008 02:05PM by Cheap!.
Re: How is it made?
January 14, 2008 02:47PM
It's PTFE (Teflon). There's a set of DIY instructions here: [reprap.org]
Re: How is it made?
January 14, 2008 04:04PM
i actually did not make any of them, i had them made for me.
i believe a lathe was used, and it was tapped to 3/8"
Anonymous User
Re: How is it made?
January 14, 2008 04:41PM
I was thinking something like this for the new part. Sorry I can't draft.
Re: How is it made?
January 15, 2008 05:32PM
the problem with that is getting it made. i'm not entirely sure how you'd do it, but you'd probably have to start with a sizeable rectangular chunk of PTFE, lathe it down to the right size, drill it, tap it, and then cut the holes. that takes the relatively cheap part to being an expensive part.
it would work if it was just you making 1 part, but what we need to consider is that eventually hundreds (or thousands) of these parts will need to be made. thats a whole new design challenge.
Re: How is it made?
January 15, 2008 09:00PM
order a hundred of them from an injection moulding company. I'm sure that would work.
Jay
Re: How is it made?
January 16, 2008 05:18AM
Injection moulds typically cost $10000 - $100000, so you need to make a lot more than 100 of something to make it economical and you have to be sure your design is correct. That is why RP techinques like FDM exist.
Re: How is it made?
January 16, 2008 01:23PM
O ok, yea that makes sense.
Jay
