Output a stl face as dxf
May 29, 2013 05:31AM
Is there the feature in any freeware program that will allow me to select the face of an stl object and export that as a dxf?
Thanks
Ben
Re: Output a stl face as dxf
May 29, 2013 06:54AM
OpenSCAD - 3D to 2D Projection should do it for you.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
May 29, 2013 07:36AM
Whoops read that the wrong way round to start with, thanks will take a look
Ben
Edited 1 time(s). Last edit at 05/29/2013 08:10AM by plexer.
May 29, 2013 10:25PM
You can do it in FreeCAD too. It requires a few more steps, but there are no typing commands involved. OpenSCAD is great if you have a programmer's mindset, but I prefer a GUI even if it takes a few more steps. Only mouse clicks are needed here except for typing the file name. winking smiley
1. Import the STL into FreeCAD.
2. Select the object in the 3D view or the Project tree.
3. Go to Part --> Create shape from mesh
4. Select the newly created shape then go to Part --> Convert to solid
5. Select the new shape and clean it up with Part --> Refine shape
6. Select the refined shape and go to File --> Export. Save as DXF.
Edited 1 time(s). Last edit at 05/29/2013 10:27PM by NormandC.
May 30, 2013 06:07AM
NormandC thanks for that but as I'm designing using scad anyway the other suggestion was perfect.
Thanks
Ben
