Cutting an object in to pieces to 3d print January 06, 2014 06:54PM |
Re: Cutting an object in to pieces to 3d print January 06, 2014 08:54PM |
Re: Cutting an object in to pieces to 3d print January 06, 2014 11:21PM |
Re: Cutting an object in to pieces to 3d print January 10, 2014 07:37PM |
Re: Cutting an object in to pieces to 3d print September 12, 2014 10:11PM |
Re: Cutting an object in to pieces to 3d print September 16, 2014 02:38AM |
Re: Cutting an object in to pieces to 3d print September 16, 2014 04:24AM |
Re: Cutting an object in to pieces to 3d print September 16, 2014 06:34AM |
Re: Cutting an object in to pieces to 3d print October 04, 2014 07:45AM |
Re: Cutting an object in to pieces to 3d print November 22, 2014 06:30AM |
Xabbax
With the new Repetier-Host 1.0.4 you can cut your stl file any way you like.
Re: Cutting an object in to pieces to 3d print November 23, 2014 01:27AM |
maboo
I sometimes use FreeCAD to cut objects, just the way it is done with OpenSCAD.
- Take a cube and position it it over the part that you need to cut away, then make a boolean operation (difference) and there you go.
Just remember that cutting those .stl meshes will brake your objects hull and create a manifold object.
So after cutting go to netfabb and repair the object first.
Depending on the shape and complexity, netfabb may close some (intended) holes... so inspect you part before printing.
maboo
Re: Cutting an object in to pieces to 3d print December 31, 2015 06:52AM |
