Camera shoulder rig for DSLR
Posted by MarcusWolschon
Re: Camera shoulder rig for DSLR
April 03, 2011 05:57AM
And an accessory holder for anything that attaches to a 1/4" bolt or a hotshoe.
(In my case, a Sennheiser MKE400 directional microphone for a hotshoe)
blog post:
[marcuswolschon.blogspot.com]
design on thingiverse:
[www.thingiverse.com]
Edited 1 time(s). Last edit at 04/03/2011 05:59AM by MarcusWolschon.
* homeprototype free 3d design repository
* Blog
* Google+
April 14, 2011 05:37AM
Hello ewaters,
found anything?
Any idea about the T-connectors?
I haver an idea for a hinged one but no time to finish
and prototype that design yet. sad smiley
* Blog
* Google+
April 16, 2011 08:09AM
After being able to mount a Zoom H4n audio recorder to the rig via the "accessory holder".
I now created a holder for it's remote.
You can use all of the remote's functions with your left (or tight) hand without letting go of the rig.
You also have it's indicator LED in view to find our about audio levels being about to spike (yellow) or spiking (red).
Blog post:
Thingiverse:
...oh and a stronger version of my inperfect T-connector too.
Blog post:
Thingiverse:
Edited 2 time(s). Last edit at 04/16/2011 08:12AM by MarcusWolschon.
* Blog
* Google+
April 17, 2011 01:30PM
...and an adapter for a display-viewfinder
Blog post:
Thingiverse:
Image error
File not found.
open image URL
* Blog
* Google+
April 19, 2011 08:08AM
This thread is great, can't wait for the printer to arrive in a few weeks...
Keep it up :-)
I have a GH2 so it will fit perfectly.
April 19, 2011 08:13AM
> Keep it up :-)
It will.
Same size as both my GH-1.
Even the display-viewfinder fits.
I'm preparing to make a video on how to build it.
It will be finished well after easter. Have to go to
EasterHegg first.
What printer are you getting?
Edited 1 time(s). Last edit at 04/19/2011 08:16AM by MarcusWolschon.
* Blog
* Google+
June 14, 2011 12:54AM
I added a geared follow focus to the collection of 15mm DSLR rig parts
smiling smiley
It uses an industry standard 0.8 pitch and I tested it to be compatible with commercial gear.
(Use these lens gears on a commercial system or lenses with commercial lens gears in this follow focus.)
* Blog
* Google+
July 01, 2011 12:14AM
Marcus,
Great project. I am just getting into the RepRap thing ordered a kit to get me started but am more than happy to offer feedback on any of your design elements/bounce ideas off of as this is one of the projects I envisioned from the start.
In terms of all the nuts and bolts in the pic one of the things I wanted to try for myself is to create a c-clamp kind of thing using the thread kit off of thingiverse and set it so those would grab the bars etc rather than using metal bits. Not sure if it would grip enough however.
The follow focus addon would be good too. How have you found the shoulder mount so far?
Anyhow once I get my head around the design software this weekend I'll have a look at the files, great work looks spot on.
July 01, 2011 12:29AM
The shoulder mount works great, however it's quite large to transport.
* Blog
* Google+
July 01, 2011 12:34AM
Did you resolve the bolts through the bars issue?
July 01, 2011 12:36AM
Not with ABS.
It can probably be resolved with a hinge.
* Blog
* Google+
Rod Bonatro
August 03, 2011 02:56PM
They have a pretty cool device you can mount a follow focus to at www.habbycam.com
It's pretty inexpensive for such high quality. I was definitely pleasantly surprised!
http://www.habbycam.com/Habbycam_DSLR_Cage_and_15mm_Rod_KIt_p/supports_cage_rod_kit.htm
August 30, 2011 09:35AM
I would not call $599.00 inexpensive.
I could get 2 good cameras for that kind of money.
* Blog
* Google+
Grikmeer
re. Camera shoulder rig for DSLR
September 06, 2011 01:06PM
Hi. I'm currently trying to repair a Seagull Shoulder Rig and, as you seem to building your own, I think you might be able to help me with the piece which needs replacing.
The problem is that the plastic connection which joins and holds the extending arm in place snapped. I don't know a correct term for the piece, or anywhere to find it. If anyone could help me, I'd be grateful... I can be contacted at grikmeer [a.t.) gmail {dot] com
September 06, 2011 03:39PM
Hi, I'm trying to find a replacement part for a Seagull Shoulder Rig, and as you're building your own I think that you may be able to advise me.
The plastic fastening which locks the extending arm has snapped, necessitating a replacement, but I'm not sure what it's called or where to go about getting a replacement. Could you advise me?
September 08, 2011 05:08AM
I don't have models of replacement parts for the Seagull.
* Blog
* Google+
