-SPECIAL SHOWROOM MODEL CLEARANCE- *Priced to move ASAP* Discounted by over 50% of the retail cost. Serious inquiries only.
For Sale, In Stock. Showroom model, never been used to cut parts, only used as showroom model. Priced to move asap. Fully loaded with accessories. Financing available through 3rd party. Call for pricing. First come first serve.
email to
dan@danhatech.com
Port Coquitlam, BC, Canada
Machine: CNC Machining & Turning Center
Control: FANUC 0i TB Advanced Control
MACHINE SPECS:
Chuck Size 8" 203mm
Swing over bed 20" 510mm
Max. turning diameter 12.59" 320mm
Max. turning length 19.68" 500mm
Travel X/Z axis 6.73"/21.65" 171mm/550mm
Spindle speed 45-3500rpm
Spindle motor servo alpha digital 20 HP Fanuc 15 kw
X & Z servo motors alpha digital Fanuc
Number of tool stations 12
Spindle bore 2.95" 75mm
Bar capacity 50-60mm
Type of spindle nose ISO A2-6
Spindle bearing inner diameter 4.33" 110mm
Quill stroke 4" 100mm
Tailstock taper MT4
X-axis rapid feed rate 630IPM 16MPM
Z-axis rapid feed rate 787IPM 20MPM
Slide way type Linear guide way
Turret index time 0.3 seconds
Machine dimensions 97.0" x 61.41" x 74.40" 2465 x 1560 x 1890mm
CNC LATHE ACCESSORIES INCLUDED:
Lighting device
Air blow for chuck (M Code)
Coolant system
Coolant for chuck and internal coolant system to turret
Splash guard
Heat exchanger (to cool electrical cabinet)
Wedge block for fixing (8 pcs.)
5 feet automatic multiple bar feeder (with wiring & PLC upgrade) DH-65L FEDEK--LNS GROUP
Operating manual for NC controller
Auto/Manual Chip conveyor with cart
Operating manual
Automatic Parts catcher (M Code)
Maintenance manual for NC controller
Foot switch for chuck
Part program memory length (640 meters)
12 position hydraulic turret
Inner hold tool holder for turret (4 pcs.)
Toolbox equipped with tools
Base blocks (4 pcs.)
Manual tool setter
Tool holder bush-inner hole
Collet chuck holder
Hollow rotary hydraulic chuck (Kitagawa)
Ridged tapping (M Code)
8" 3-jaw hydraulic chuck (Kitagawa)
Graphic system
Main spindle Fanuc alpha digital servo motor 20HP
Tailstock
Integrated hydraulic unit
Quill with live centre MT4
Cycle finish light
X and Z axes Fanuc alpha digital AC servo motor
Fanuc 0iTB advanced control
FULLY LOADED!!!
open |
download -
(27.7 KB)
open |
download -
(37.9 KB)
open |
download -
(37.9 KB)
open |
download -
(36.6 KB)
