3D printer filaments
September 18, 2012 03:29AM
Hello, everybody
My name is Caren, I come from China.
I'm glad to be here with everyone learning together.
We produced a 3D printer filament. I was responsible for sales.
Here are selling 3D printer supplies. Wholesale can provide.
[www.ebay.com]
Re: 3D printer filaments
October 11, 2012 01:58AM
Hello guys,
Do you want to get qualified filaments?
This is CHINA BEST TECHNOLOGY LTD. located in HK, spcializing in top-ranking filaments. Our project team is built by engineers from Germany and China.
Advantages of our filaments :
1. Reliable quality: With strict in line quality testing approval by laser & automatic systems.
2. Safe and immediate delivery: Our warehouses in different countries will make sure goods
reach your local place within 7 days
3. Competitive price: CIF Price USD 11-35/kg depending on different markets and quantity.
Pls visit our website: www.3d-printer-filament.com to apply for up to 45% discount off samples for testing!!
Many professionals and home users already became our partners, returning to us with good feedback. Pls contact us if you have interest in trying our products.
Best regards
Cathy Zhan
Email: [email protected]
Re: I sell 3D printer filaments
December 24, 2013 01:36AM
Hello
We are a leading 3D printer fliament suppiers(Jpson 3D system) from China, We offer high rank pla filament and abs filament.
If you have interesting with our company you can go our international website to browers our products.
Our website is: http://www.jpson.com
OUr email is info@jpson.com[email protected]
Edited 1 time(s). Last edit at 12/24/2013 01:37AM by jpson.
Jpson 3D printer filaments China
We sell ABS filaments, PLA filaments. PVA filaments,
Anonymous User
October 04, 2014 10:56PM
our chinese website 深圳市众景优品科技有限公司
Bulk order, please contact: esunpla@yahoo.com or westyang168@hotmail.com, 3 years experiences produce, we supply high quality
and good price , we have some very cheap retails in aliexpress, for try testing, only $8/kg,exclusive shipping, total price about $28-$50/kg/roll.
3ddplas_logo
We start this business from 2011 recorded on Flickr
Snap39
The most stringent quality control procedures, each filament line go through over 1.85mm nozzle tube to ensure jam free,inpurities free.
       There are lots of factory can do like laser detect on line,eye sight detect and hand calipter detect, but it is far away enough. For example, once find a problem and do again,how to stop the working machine,it is a long time and complex work?
     And, the laser detect will scan every 0.2 second, it is just 0.002 second for a inpurities which length 2mm pass,even the laser machine can catch this accident data, human can't sense it .More over, it is impossible require for a worker keeping see the laser data screen for 24 hours and no fling . So some inpurities ,knot are undetected. For every users of 3d printer know, each point of accident will make nozzle jam.
    We begin to add a new procedure first in China that all filament go through a 1.85mm nozzle tube to avoid inpurities and knot.In this experient we find the inpurities are not compate with plastic resin, even once that is a tiny point ,will be detected and filament will break with stretch tensile and inertia , to make knot free and inpurities free.
    We will do 10kg first and then rewind to 1kg, as show below
20140801_124413_东环二路 20140801_124326_东环二路(1)
1.85mm nozzle tube drawing as show below:
最严格的生产方式jpg
produce site diameter control and feed back system: 3.0mm [v.youku.com], 1.75mm [v.youku.com]
    We are a professional manufacture and factory, we do in this industrial for lots of years, no matter what problem you have , we will give you a professional assist and help. we have a group of materials graduated engineer do much professional works.
组图
Printing suggestions
1)not required heat on bed, stick with 3M scotch blue tape or glass plate;
2)nozzle temerature suggest 210-230 degree, printing rate 75-85mm/min, not suggest faster;
3)layer thick 0.1mm+, not suggest smaller to make machine over load or shaking ;
4)suggest a extruder system with spring, TPFE tube insde aluminum or stainless steel tube o avoid heat transmit, only PLA filament is heated on the place of melted, other place of not melt should be well cool. Then PLA filament won't stop in the inject tube;
TB2GMCvXVXXXXcEXXXXXXXXXXXX-604424433.jp
5)should clean the nozzle every short time ,clean some over heat resin carbon particle.
Above picture show the PLA raw material grade is Natureworks 4032D ,some propeties below:
Property
Unit
Test Method
Test Condition
PLA
Tensile Strength
kg/cm2
( MPa)
ASTM
D-638
( ISO527)
23deg
55
Tensile Elongation
ASTM
D-638
( ISO527)
23deg
10
Flexural Strength
kg/cm2
( MPa)
ASTM
D-790
( ISO178)
23deg
650
(58)
Flexural Modulus
kg/cm2*104
( MPa)
ASTM
D-790
( ISO178)
23deg
4.3
(4800)
Izod
Impact Strength
kg-cm/cm
( J/m )
ASTM
D-256
( ISO R180 )
23deg
1/4''
4
(43)
Vicat Softening
Temperature
deg
ASTM
D-1525
(ISO306cool smiley
Annealed
80deg×2Hr
1/8''
58
Heat Deflection
Temperature
deg
ASTM
D-648
(ISO 75/A)
Annealed
80deg×2Hr
1/8''
50
Melt
Flow Index
g/10 min
ASTM
D-1238
( ISO1133 )
200deg×5Kg
( 49N )
5
Molding
Shrinkage
FCFC
Method
23deg
0.2~0.3
Specific Gravity
ASTM
D-792
( ISO1183 )
23deg/23deg
1.25
For the last some years, we do hard works to improve PLA formulation to make it better suitable for more and more different 3d printer.
PLA is a crystal material, and as hard as PMMA and PC, together with absord heat will turn from amorphous in room temperature to crystal one, and will make jam when 3d print.If without a well cool patch between nozzle and extrude entrance , PLA soft point is only 50 degree, extrude to nozzle will affect by heat turn to soft, that also will jam.
We do a lots of works to make PLA less trend to crystal and less trend stick to the PTFE ,aluminum,stainless steel tube.
Choose our PLA, very less trend nozzle jam, the whole process much smooth!
包装标题栏
plastic spool is inner hole 56mm, size is 200*75*56mm
盘子包装
Paper carton packaging, we have 2 kind each hold 5 rolls and 12 rolls, size is 22*22*48cm and 43.5*43.5*29.5cm
纸箱包装
