New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 02, 2012 03:25PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 02, 2012 05:01PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 07, 2012 11:30AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 08, 2012 04:51AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 12, 2012 07:08PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 13, 2012 01:35AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 18, 2012 02:05PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! November 21, 2012 09:24PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 01, 2012 11:52PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 02, 2012 06:57AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 03, 2012 09:04PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 04, 2012 01:33AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 04, 2012 07:21AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 27, 2012 05:03PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 27, 2012 05:15PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 27, 2012 05:18PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 28, 2012 06:31AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 28, 2012 06:42AM |
The DRV8825 driver IC has a maximum current rating of 2.5 A per coil, but the current sense resistors further limit the maximum current to 2.2 A, and the actual current you can deliver depends on how well you can keep the IC cool. The carrier’s printed circuit board is designed to draw heat out of the IC, but to supply more than approximately 1.5 A per coil, a heat sink or other cooling method is required.
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 29, 2012 06:25AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 29, 2012 09:27AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 29, 2012 09:56AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 29, 2012 11:33AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! December 29, 2012 03:55PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! January 13, 2013 09:32PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! January 14, 2013 05:22PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! February 04, 2013 08:49PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! February 05, 2013 12:36PM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! February 28, 2013 12:31AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! February 28, 2013 02:40AM |
Re: New Pololu DRV8825 Stepper Motor Driver: A4988-compatible with more power! February 28, 2013 11:57PM |
