[RRW] Megatronics v2.0 available! €79.99
February 09, 2013 04:34AM
Announcing the direct availability of Megatronics v2.0, the new version of our populair Megatronics line of Reprap Electronics. This board is the best value for money, all these features for only €79,99.
[reprapworld.com]
Major features:
Atmega2560
Powerful Atmega2560 processor with 256 kB memory, running at 16Mhz
Thermo couple (2x)
On board support for connecting two thermo couples
SD Card
Autonomous printing from Micro SD card on board
LCD support
Hooking up a LCD is pretty easy. The Wiring is compatible with most LCD screens. We do not sell the required wiring yet, but you can use 6x2-wire cable.
Five MOSFETs
The board has 4 MOSFETs (4x 25A) to support fans and extruders and 1 MOSFET (IRLS3034PBF) for the heated bed
Up to 6 stepper drivers
Compatible with RAMPS, 6 slots for stepper drivers (not included). Modularized to make replacement easy for damaged drivers. This board also support the new DRV8825 driver from Pololu [www.pololu.com].
Support for many peripherals
The board's functions can be easily extended with LCD, keypad etc. See the connectors section for more information
Check the wiki [reprap.org] for more information
reprapworld.com
PLA, ABS, PETG multiple colors (3 and 1.75 mm) €16,49 / kg
Megatronics 3.0 €79.99 / Minitronics €37,19
Re: [RRW] Megatronics v2.0 available! €79.99
February 09, 2013 10:46AM
Here is a vid of the new board printing:
[www.youtube.com]
reprapworld.com
If I power the board with 24vdc will that give 24vdc to the fans or will they be 12VDC?
I notice the Electronics side of the board is 7 amps. If I have 7 motors connected at 24vdc input and each motor can draw 1.6 amps. Along with two 40Watt 24vdc cartrige heaters. And 2 fans. Will the board handle it. The 7th stepper is on your external stepper card still powered from the 12v (24v) out and the 5vdc out on the board.
Donny
April 22, 2013 02:21PM
If you put 24V on 12V1 everything will be 24V. Don't jumper SRC12V in that case.
The 12V1 circuit is fused with a 12A fuse. Both extruders should use 1.7A each, so it's close to max I think. But I am not sure on how much the stepper drivers actually draw while running. Maybe someone else can answer that.
reprapworld.com
Ok no jumper. I have 12vdc fans on my extruders. I notice there is a 0 to 255 setting for speed in the firmware (Marlin) for the fans. If I set the max to 127. Will that limit the max voltage to 12vdc instead of 24? Or does it not work that way? What is the M codes to turn on each fan?
Donny
April 22, 2013 03:29PM
M codes depend on your firmware, M106 for fan 1 on Marlin. Don't think Marlin has support for two fans, but I can be wrong here.
PWM will put 24v is short burst through the fans. I won't advise that. Best is to use a power regulator 7812.
reprapworld.com
