Printerboard REV D in stock ! ! ! spinning smiley sticking its tongue out
April 19, 2013 02:18AM
Hello Every one ! ! ! smileys with beer
We are back with the stock of Printerboard REV D .
Its price :- $104.99.
Its Details are as follows:-
Fully assembled, tested Printrboard Electronics loaded with the latest Marlin firmware.
The Printrboard electronic set was designed by members of the Printrbot team in order to eliminate the production and/or functionality shortcomings of older RepRap electronics sets. Printrboard improves upon the previous production-grade electronics set (Gen6) by adding heatbed and SD card support, reverting to 1/16 microstepping Allegro stepper drivers, and improving connectivity reliability and reducing cost by elimination of the FTDI UART chip.
Printrboard is by far the fastest and most reliable RepRap motherboard to date--and at an unbeatable price.
Features :
• Atmel AT90USB1286 Microcontroller
• Four integrated Allegro A4982 Stepper
• Four 5V Endstop Connectors Supplied
• OnBoard SD Card Slot
• 2 N-MOSFETs for Extruder and Heatbed control
• 1 N-MOSFET for low power Fan or motor
• Revision D
• Green Power LED
• 4 layer, 2oz Cu PCB with ENIG Finish -- Excellent current handling & thermal dissipation
• LUFA CDC Bootloader* and Marlin RC2 firmware Pre-Installed
Softwares :
• Aurdino For Printrboard- For Working Printrboard Board Configuration
• Marlin Firmware - Lincomatic Marlin for Printrboard
• CDC BootLoader.zip - CDC BootLoader For Printrboard
Note:- you can get these software from our site. click here
Options :
Install Kit :
• 3 Pieces of 3 Pin Molex with Mechanical switch Pre Soldered.
• 2 Pieces of 2 Pin High Temperature Molex (for Thermistor).
• 1 Piece of 2 Pin Molex (for Fan).
• 2 Pieces of 4 Pin High Temperature Molex (for Heaters).
• 1 Piece of Micro USB cable.
• Resistor
• Thermistor
All Molex are 600 mm Long
Note:
You will receive just PrintrBoard as in Picture.
Z Parallel Cable for Prusa : If you are making Prusa, which has needs 5 stepper motors. Then with the help of our Parallel Z motor cable you can drive 2 Z motors. If your printer has only 1 Z motor, then you do not need this cable.
If you have any quereies then drop amail at support@makemendel.com
If you need more information about it then visit here .
Thank you ! ! !
smileys with beer
