Aluminum Heated Build Plate is on SALE
Ebay listing page
It was designed to be used as heated build surface of typical 3d printer with 200 x 200 mm XY build area. Plate is compatible with MK2, MK2A and MK2B heat bed PCBs. Material is 3mm thick T6061-T6 aluminum alloy. Plate uses countersunk mounting screws to eliminate possibility of hotend running into a screw and getting damaged. Another convenient feature is the milled channel for thermistor installation on the bottom of the plate. This feature makes assembly easy and clean, thermistor wiring is hidden in between plate and heated bed PCB.
- Kit uses high temperature resistant silicone rubber spacers instead of typical springs.
- Thermistor is hidden in the milled channel on the bottom of the plate.
Links to parts drawings and assembly manual:
Plate assembly instructions
Exploded view drawing with ORD Bot Y axis
Aluminum plate drawing
See
http://www.thingiverse.com/thing:195653 for more details and downloads.
Ebay listing page
Edited 1 time(s). Last edit at 08/11/2014 10:25PM by rp1.
