AL230 3d printer + LCD
April 02, 2015 10:56PM
appearance size :470X450X400mm
Packing size: 620X500X470mm
1. LCD 2004 LCD display screen.control console
2, 5 mm thickness aluminum alloy table, more durable, heat up more faster
3, extensibility, scalable single nozzle design (standard for the print heads, already reserve the installation position) 4, SD card offline print function, SD card
5, RAMPS1.4 Control panel A4988 motor chip
6, for 1.75 mm filament (PLA ,ABS)
7,more simplely and easily to assembly and maintenance
8,linear bearings for X, Y, Z axis! Movement is more fluent, and more accurate.
9, printing precision is improved, the nozzle diameter is 0.4 mm(if you need 0.5mm,please left message to us)
10. replacing materials is more quickly (you can change different color materials, to achieve colorful model, for details, please refer to the beblow picture)
11, printing size is increased, do not worry about a bigger model.
12, the power is 24 v, 400 w, support 110 v to 220 v
