Re: Mini differential IR height sensor board September 08, 2015 12:40PM |
Fpex
Are they compatible with the duet 0.85 and can be used in a larger effector mounting a kraken?
Fpex
Do you know if it works on carbon fiber also?
Re: Mini differential IR height sensor board September 08, 2015 12:54PM |
Re: Mini differential IR height sensor board September 08, 2015 02:55PM |
Fpex
For the effector, the question is more about the fact that the sensor will be somewhat more on the side than in, let's say, a riprap head. Not by much, but a little bit as the effector will be somewhat larger than a traditional one (more like the SeeMECNC one).
Re: Mini differential IR height sensor board September 08, 2015 03:02PM |
Re: Mini differential IR height sensor board September 09, 2015 02:36AM |
Re: Mini differential IR height sensor board September 09, 2015 03:47AM |
Re: Mini differential IR height sensor board September 09, 2015 10:58AM |
Re: Mini differential IR height sensor board September 09, 2015 12:47PM |
Re: Mini differential IR height sensor board September 09, 2015 01:05PM |
Re: Mini differential IR height sensor board September 09, 2015 01:57PM |
Re: Mini differential IR height sensor board September 09, 2015 02:36PM |
Re: Mini differential IR height sensor board September 09, 2015 03:50PM |
Re: Mini differential IR height sensor board September 16, 2015 09:41AM |
Re: Mini differential IR height sensor board September 21, 2015 05:22PM |
Re: Mini differential IR height sensor board September 24, 2015 12:44PM |
Re: Mini differential IR height sensor board September 24, 2015 03:23PM |
Re: Mini differential IR height sensor board November 03, 2015 12:53PM |
Re: Mini differential IR height sensor board November 11, 2015 12:21PM |
Re: Mini differential IR height sensor board January 05, 2016 03:17PM |
Re: Mini differential IR height sensor board January 05, 2016 06:44PM |
Re: Mini differential IR height sensor board January 06, 2016 01:41PM |
Re: Mini differential IR height sensor board January 06, 2016 07:36PM |
abuharsky
After replacing wires and connectors, cleaning pins with sandpaper, etc - the problem seems to be solved. I will test sensor 1-2 weeks and reply if some problem appear.
Thank you for advices.
ps
I also checked that when sensor is connected to the already loaded Arduino - the LED blinks twice. Maybe you can take this into account in the next revisions of your wonderful sensor.
Re: Mini differential IR height sensor board January 08, 2016 11:46AM |
dc42
I'm glad you got it working. If you have a multimeter, what would be really helpful to me is if you could disconnect the sensor, and connect your multimeter in place of the sensor Out and Gnd connections. Then turn on the power, and time how long it takes before the meter reading stops being zero. That will tell me how long the sensor needs to wait before checking whether the pullup is enabled. In my tests with RAMPS/Marlin, 4 seconds was enough, but evidently your configuration takes longer.
Re: Mini differential IR height sensor board January 09, 2016 05:07AM |
Re: Mini differential IR height sensor board January 09, 2016 06:19AM |
Re: Mini differential IR height sensor board January 09, 2016 07:05AM |
Re: Mini differential IR height sensor board January 13, 2016 06:38PM |
Re: Mini differential IR height sensor board January 14, 2016 03:46AM |
Re: Mini differential IR height sensor board January 29, 2016 04:37AM |
Re: Mini differential IR height sensor board January 29, 2016 05:33AM |
