just sent a couple out, here is a picture of how it will arrive:
in the bag is 4 m3 bolts, 4 m3 washers and 4 m4 washers (to attach your motor), also two m3 bolts + 2 washers and 2 nuts for attaching the extruder to your printer.
all that you need are the two m3 bolts needed to put through the PTFE of your hot end, and a 2.5 drill bit and drill press/hand drill and vice
my extruder which is the same as pictured has so far extruded almost 1lb of ABS has had a constant flow all along and hasn't had any plastic stuck in its teeth so far.
Edited 1 time(s). Last edit at 11/12/2010 01:20AM by mlagana.
