9mm wide GT2 belt, Wide drive and idler pulleys
March 26, 2016 11:06AM
I have a lot of 9mm wide GT2 belt, 20 tooth pulleys for 5mm shaft stepper motors, and 20 toothed idler pulleys with a 5mm inside diameter.
Belt is just 4.75 per meter. This is the wide belt.
I also have the drive pulleys for this belt, 20 tooth, GT2 profile. These drive pulleys are made for the wider belt. Each pulley has 2 set screws. The belt mating surface is 11mm wide and the total width is about 19.6mm. These drive pulleys are 3.50 each.
I also have toothed idler pulleys for 9mm wide GT2 belt. The bore is 5mm. The belt mating surface is 11mm wide and the total width is 14mm. These pulleys are 4.00 each.
Shipping within the US is a flat 3 dollars no matter how much you order.
Start getting better prints with wider belts today.
All prices are in USD. I take PayPal only.
If you get wider belt you will need wider pulleys, just FYI.
