Anycubic 3D Printer Pulley Version Linear Guide DIY Kit
Kossel Delta Large Printing Size 3D Metal Printer Print Size (XYZ)
ulley: 180X300mm Linear:180X300mm /
choose large print size 230x300mm from upgrade .
Key Features:
1. Trigorilla mainboard exclusively developed my Anycubic R& D Team. Trigorilla is all in one mainboard shows outstanding functionality and stability .Simple Installation , Easy operation, Extensible function, selectable drives , wide voltage input, compatible with marlin firmware.
2. Injection molded with high strength and toughness of uniform shape and size minimizes printing error.
3.High quality aluminium extrusion european standard 2020 electrophoretic black.
4.Double cooling fans
5.High quality extruder
6.Structural stability, appearance of simple, easy installation and maintenance.
7 Build volume 180 x 300mm Kossel plus is 230 x 300mm
8 Kossel printer available in two options Pully version and Linear guide Version
9 Color available yellow red and Black
(Please tell us what kind of plug you need , EU or US plug ,Or we send you default EU plug )
