I've been developing this hot end design for about three months, and it is proving to be very reliable.
Image is not representative of the kit. Just some of the components
Look here for more information on the Wildseyed Simple Hot End design.
Kit includes:
1 - Greg's Hinged Extruder Body
1 - Greg's Hinged Extruder Large Gear
1 - Greg's Hinged Extruder Small Gear
1 - Greg's Hinged Extruder Idler
4 - Neoprene/Metal Washers (These replace the tension spring)
3 - 608 Roller Bearings
1 - 40mm length PTFE Rod, drilled and turned
1 - 1/4" Brass Coupling
1 - MIG Welder Tip, Press fit and shaped
1 - 5Ohm 5 Watt Power Resistor
1 - 100k Thermistor
4 - M4 Set Screws for fastening hot end to extruder body.
Miscellaneous hardware screws and nuts.
I take the guess work out of assembling the hot end, you do the rest. $100 + Shipping
For more information, or to place an order, email me wildseyed at gmail com with "Wildseyed Simple Hot End Kit" in the subject line.
I only accept money orders, and credit card payments (5% extra fee). Absolutely no PayPal. Credit Card payments are processed through Square Up.
