Which desktop 3D printer for daily printing of varied models ?
March 02, 2013 04:11PM
Hello, I need a machine to print 3D objects for many people with different needs. Basically a single person will be operating the printer which would be printing all day and all week.
The requirements are:
• cheap raw material
• 1500€ / $2000 max
• fast
• quiet
• reliable on printing/software/hardware
• responsive manufacturer support
• desktop/portable
• support different type of raw materials
• large build size
• low and high resolution
• raw material in different colours
• Mac compatible
Which one do you recommend ? (not necessarily a reprap)
Re: Which desktop 3D printer for daily printing of varied models ?
March 03, 2013 12:16AM
eye popping smiley eye rolling smiley grinning smiley
Well Good Luck with that!!
But seriously some of your requirements are impossible combinations.
$2,000.00 MAX & responsive manufacturer support
fast & quiet:
Well, most machines are relatively quiet but I don't know if you would want it on your desk while you are working.
But then you didn't mention whether you wanted to print in PLA or ABS. ABS greatly benefits from being entirely enclosed and could then be made to be very quiet at the same time.
low & high resolution:
Almost all well tuned Mendel variants can print a layer heights between 0.2 mm and 0.5 mm.
Very well tuned Mendel variants can easily print at a layer height of 0.1 mm and some down to 0.05 mm.
However at these layer heights it is anything BUT fast...
One of the currently popular RepRap designs such as Prusa Mendel, Mendel MAX or Mendel90 can meet most of your requirements and support you can get here or on IRC.
large build size
What does this mean? Most Mendel variants have a bed size X x Y,x Z of 200mm x 200mm x 100mm up to around 200mm x 200mm x 200mm. Is this large enough?
Most RepRap software is multi platform so Mac compatible is not a problem.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
March 03, 2013 12:03PM
I've read "Make Ultimate Guide to 3D Printing" so I have an idea of what's available, but it doesn't tell me if it's suited for intensive use.
> I sent an email to 17 manufacturers and those who didn't reply had the most expensive printers (3Dtouch,, lulzbot AO-100, Replicator 2), go figure.
fast & quiet
> a good number of printer do both, but I still might cover mine with soundproof material
> I was thinking of 0,2 to 0,05mm. Some can go lower than what their specs says, so I don't know.
large build size
> yes about this large. In Make magazine those with the largest were around 9000cm3
It sees that Make didn't review any reprap printer, only descendant of them. Is there a comparative table of repraps ?
March 04, 2013 09:18PM
> figure.
Are you saying LulzBot didn't write you back? That is a big oversight, if I understand correctly. Can you tell me the address it came from and/or the Subject: and I'll look into it.
Thanks,
-Jeff
March 06, 2013 03:32PM
@corngolem: ping! I searched around our email archives and I can't find anything that matches your name. Can you send me the From: email address or a Subject: I can search for?
Thanks,
-Jeff (from LulzBot)
March 07, 2013 09:47AM
@corngolem: ping
-Jeff, from LulzBot
March 08, 2013 10:25AM
@corngolem: hello?
March 08, 2013 02:44PM
For some reason I was not notified of the new messages, and I don't know what this ping is supposed to do.
jebba, I did get a reply from lulzbot (since first post), just very, very late, same for makerbot.
It's nice to see that you care about the issue but don't flood the thread...
March 08, 2013 06:26PM
Can you send me (via here or pm as you like) the email address and/or Subject: from your email so I can look it up? What do you consider "very, very late"? We generally answer within 1 business day, but typically if it is during business hours it will be within an hour or two.
Sincerely,
-Jeff
March 08, 2013 06:37PM
No need, and stop hijacking the thread will you.
Edited 1 time(s). Last edit at 03/08/2013 06:38PM by corngolem.
March 09, 2013 03:27AM
Just send me a Subject: and/or email address and I'll look it up. At least answer what you consider "very late"?
March 09, 2013 03:42AM
very late = 8 days
if you think your behaviour here is professional or giving a better image of your company, you're wrong
March 18, 2013 06:47PM
corngolem Wrote:
> very late = 8 days
> wrong
Yawn.
