STEEL CORE gt2 belt [or dyneema, kevlar, etc]
Posted by Tomek
October 01, 2015 02:51PM
Hi, I'm planning on putting my belt under higher tension than is typical. Does anyone have or know where to source higher quality GT2 belt?
I went through the entire wiki on belts, and T2.5 has a couple german sources for steel core, but GT2 is only neoprene/fiberglass everywhere I look.
Sources, leads, feedback, etc, anything would be appreciated. I'm not having any luck at all!
Regards,
-Tomek
Re: STEEL CORE gt2 belt [or dyneema, kevlar, etc]
October 02, 2015 03:39PM
If anyone else is looking...I ended up biting the bullet and finding a few suppliers on aliexpress. We'll see if that works out.
I also found a single seller on ebay, when I stored for "steel cord gt2" instead of "steel core gt2" [Cord and core both kind of do make sense for naming the internal type.]
For some reason the steel stuff ends up being with polyurethane instead of (what I think the regular fiberglass belt uses) neoprene.
I'll run a couple tests till failure but I don't think I'll get good performance spec sheets from the aliexpress seller :s.
April 02, 2016 07:44AM
Any follow up on your steel core belts?
November 09, 2016 11:29AM
Well I've been using them on my corexy for around a year and recently some of the steel wires are snapping. I am using 16 tooth pulleys.
They work well but the steel does fatigue eventually. Not bad value though from China. Might try kevlar belts next see if they last longer.
Edited 1 time(s). Last edit at 11/09/2016 11:42AM by DjDemonD.
Simon.
[www.precisionpiezo.co.uk] Accurate, repeatable, versatile z-probe plus piezo discs, endstop cables, pt100, 50w heaters. PT1000 cartridge sensors plug straight into duet boards and others.
Published:Inventions
