Alt Select Electronics
Revision as of 16:56, 17 August 2011 by Joem (talk | contribs) (Stepper Drivers)
This page has been flagged as containing duplicate material. An editor has suggested merging this page or section into Alternative electronics. (Discuss)
THIS page is an extremely rough draft. You can help us improve it. (Someday this page will document many of the known-working systems. A few known-working systems are already documented at RepRap Options).
Alternative Build Documentation Build Documentation
Do not let the size of this page discourage you, you have many electronic choices. At the end of the day you need these fundamental components
  • A Mainboard
  • Stepper Drivers
  • Endstops (Optional, see here)
How you get there is up to you. If you don't want to make these kinda of choices simply follow an "offical" build (Color choices below).
        • Add stuff about Extruder Controlers
BlueMendel "Official"
OrangeHuxley "Official"
Mainboard+Stepper Drivers+Opto Boards(All In One)
These all in one kits let you get up and running the fastest but tend to offer less flexibility in blah blah blah
PicNameAuthorLicenseBased onRepRap EtchableDesigned FirmwareStatusNotesPurchase Assembled~Component Cost
Gen 6CamielGPLATmega 644NoFiveD firmware with addons/changesExperimental Mendel-parts.com - 130 EUR
PicNameAuthorLicenseBased onRepRap EtchableFirmwareStatusNotesPurchase Assembled~Component Cost
Gen7 Layout.pngGen 7TraumflugGPL v2ATmega644 or ATmega644PYes Teacup, FiveD or any otherRelease 1.0Single Sided PCB, Uses pololuNo
Finished-pcbs.jpgPololuAdrianbowyerGPL v2Arduino MegaYesFiveDExperimentalNo
Rampsprepped.jpgRAMPSjohnnyrGPLArdrino MegaYesTonokip_Firmware, TeacupExperimentalThis is a shield designed to go over an Arduino Mega BoardUltimachine - $30-$200
Sanguinololu-0.1-top.jpgSanguinololuJoemGPL v2ATmega644PUntestedanyReleaseTiny, low-cost fab'd PCB, Uses pololuNo$30USD at Mouser
Mainboard
PicNameAuthorLicenseBased onRepRap EtchableBuilt-In OpticsFirmwareStatusNotes~Component Cost
Motherboard 1 2-motherboard-modified-small.jpg1.2 - Gen 3atmega644pNoNoFiveDReleased
RepRapOneDarwin-darwin.jpgSomething Ancientatmega644pNoNoProclarush Taonas 1.0Retired
Electronicshookedup.JPGTekzone Remix MainboardKymberlyaandrusatmega644pNo?Working
Stepper Drivers
PicNameAuthorLicenseBased onRepRap EtchableSoldering RequiredRating Per CoilStatusNotesPurchase Assembled~Component Cost
Cache-3314977742 1b6fce154e.jpgStepper Motor Driver 2.3GPL Allegro A3982?No?Surface Mount2AReleasedPCB Here
StepStick.Top.jpgStepStickGPL V2 Allegro A4983 & A4988?Reflow2ADevelopmentA drop in replacement for any Pololu A4983/A4988 driver. Four drivers on one board fit perfectly into Sanguinololu or break apart for other electronicsCheck eBay for Stepstick "Twigs"~$25 USD (for all 4 drivers)
Endstops
Extruder Controller
