Belt
Revision as of 08:16, 21 June 2013 by Naught101 (talk | contribs)
Make sure you get a Contitech Synchroflex tooth profile, or equivalent, which allows enough room for chunky teeth. For example, HTD (round profile) does not allow enough room for teeth on a tight diameter.
RepRap attempts to print its own parts wherever possible. This includes toothed drive pulleys. 5 mm pitch (or imperial equivalent XL pitch, 0.2") belts have been investigated because at the time of research a 5 mm pitch was the most achievable to print. See the Mendel assembly data sheet for the belt specifications.
Splitting wide belts
Wide belts need to be split to a width of 5mm. This can be achieved using the belt splitter jig (two reprapped parts).
If you don't have a belt splitter jig you can split the belt pretty easily as follows:
  • Put the blade from a Stanley knife in a vice (just the metal blade). Make sure it is steady.
  • Take the belt, and pull it slowly over the knife. Have a second person pull back on the belt so it doesn't go too fast. Don't do this in your own.
Belt sizes
Belts people use with appropriate pulleys:
See also
