CoreXY
The CoreXY arrangement and the very similar H-bot arrangements are popular mechanical arrangement for a RepRap motion stage.
The CoreXY and the H-bot are a Cartesian arrangements -- they makes it easy to move the head in straight lines along axis 90 degrees from the other axis.
There is a change in the belt pattern from the H-bot arrangement to the CoreXY arrangement. The belt loads on the carriage of an H-Bot tends to rotate it around Z axis. So the positioning accuracy rely only on the stiffness of the carriages. H-bot shall be very solidly built for good accuracy. CoreXY mechanism add two pulleys to equilibrate loads and so the carriage stays always perpendicular without relying on the stiffness of the sliding mechanism. In fact, the CoreXY mechanism is the same as what was used for decades in cable based auto-parallel drawing tables. CoreXY have longer belts than H-Bot but they allow lighter construction. "A Core-XY Implementation: overcoming H-Bot design drawbacks and building a laser-paper-cutter". CoreXY The advantage of coreXY are discussed by some:[1]
Firmware option are identical for CoreXY and H-Bot.
A CoreXY and a H-bot are a parallel manipulator system. In other words, the motors on a CoreXY system or H-bot system are stationary.
Parallel manipulator systems, such as CoreXY and h-bot and Dualwire-Gantry (DW-G), typically have much lower inertia than serial stackup arrangements. The lower inertia of a parallel manipulator system, when using the same motors and the same forces, typically gives more rapid acceleration than serial stackup arrangements. (For example, the Prusa i3, RepRapPro Mendel, etc. use a serial stackup -- in other words, some of their motors are pushed around by other motors).
To maintain the low inertia, they are generally equipped with 'Bowden' tube hot-end.
In DIY world, the D-Bot, derivative of the C-bot, A V-wheel based design, had some success and is probably the most frequently self-built CoreXY. The more recent hypercube design based upon tubes also drafted interest, needing less printed parts than a C or D-Bot. An HyperCube built with very light carbon tubes have low mobile mass allowing good performance.
Some Chinese manufacturers are confusing people while presenting H-Bot printers as CoreXY (Creality Ender-4 is presented as being a CoreXY while it is an H-Bot with associated problems) [1].
Machines in standard aluminium profiles
Name | Last update | Description | Movement XY | Movement Z | Useful volume | Size | Speed (print/travel) | Link |
Vulcanus (different sizes) | may 2015 | Frame in aluminium profiles, with metal and printed parts | bearings on rods | 4 rods and two trapezoidal screws (2 motors) | 200 x 200 X 260 (up to 520 x 520 x 1500) | 440 x 440 x 600 | 300 (print? travel?) | http://www.instructables.com/id/Vulcanus-V1-3D-Printer/ http://www.thingiverse.com/thing:821066 http://www.instructables.com/id/Vulcanus-MAX-CoreXY-Aluminum-Frame-RepRap-3D-Print/ |
VSlot-CoreXY | february 2015 | Modification and update of project AluXY by zelogik/jand while using Openbuild profiles. Good documentation. | V-slot with wheels (said to be more silent) | with 2 rods 12mm and trapezoidal screw 10mm thread 2 | 210x195x240 | 400x400x500 | ? / ? | https://github.com/sdavi/VSlot-CoreXY |
C-bot | january 2015 | Profiles Openbuilds and printed parts | with V-slot with wheels, non crossing belts | with V-slot, transmissions with 2 trapezoidal screws (2 motors) | 250x250x? | 500x400x400 | ? / ? | http://www.openbuilds.com/builds/c-bot.1146/ |
RepRap-XY by "jand" | january 2015 | Machine like the AluXY by Zelogic, but with printed parts. Detailed BOM with complementary information | ? / ? | https://github.com/jand1122/RepRap-XY | ||||
AluXY by "Zelogik" | march 2014 | Aluminium frame with parts in aluminium | rods 8mm with Igus bearings, crossed belts | With two rods and trapezoidal screw | 228x236x217 | 350x350x300 | 200 / 350 | http://forums.reprap.org/read.php?397,297740 https://github.com/zelogik/AluXY |
- "H-bot type Reprap?".
- "H-bot with Fishing line concept."
- "HBot using fishing line" (actually uses the CoreXY configuration)
- "Concept: h.ORD" is a "CoreXZ" 3d printer.
- CoreXZ discussion: "Vertical H-bot with x and z axis?"
- "Tantillus sized h-bot"
- ↑ https://www.reddit.com/r/3Dprinting/comments/7ixp7d/creality_ender4_is_not_a_corexy_printer_it_is_an Creality Ender-4 is not a coreXY printer it is an H-Bot
